[postgis-users] OpenStreetMap + osm2pgsql + pgRouting into Postgis
Maria Arias de Reyna marias at emergya.es
Tue May 18 04:32:15 PDT 2010
El Tuesday 18 May 2010, Roshni Budhrani escribió:
> I have been told that this is probably because the OSM data is not
> properly noded at all intersections. If it is so, then how can i fix my
> data?
Most probably. You can try to use a bigger number on the assign_vertex_id
function, but it can lead you to wrong results too.
María Arias de Reyna Domínguez
Área de Operaciones
Emergya Consultoría
Tfno: +34 954 51 75 77 / +34 607 43 74 27
Fax: +34 954 51 64 73
www.emergya.es
