[postgis-users] OpenStreetMap + osm2pgsql + pgRouting into Postgis
roshni.spain
roshni.aruna at gmail.com
Wed May 19 04:18:03 PDT 2010
how can i be sure about this? If i get wrong results i mean ...
María Arias de Reyna wrote:
> El Tuesday 18 May 2010, Roshni Budhrani escribió:
>> I have been told that this is probably because the OSM data is not
>> properly noded at all intersections. If it is so, then how can i fix my
>> data?
> Most probably. You can try to use a bigger number on the assign_vertex_id
> function, but it can lead you to wrong results too.
> María Arias de Reyna Domínguez
> Área de Operaciones
> Emergya Consultoría
> Tfno: +34 954 51 75 77 / +34 607 43 74 27
> Fax: +34 954 51 64 73
> www.emergya.es
> postgis-users mailing list
View this message in context: http://old.nabble.com/OpenStreetMap-%2B-osm2pgsql-%2B-pgRouting-into-Postgis-tp28594661p28606823.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
