[postgis-users] I can't make sense of this.
Emilie Laffray
emilie.laffray at gmail.com
Thu May 20 09:47:45 PDT 2010
Why would you expect them to be similar? There are different sets of
coordinates.
Your first set of coordinates looks like wgs84 but you set the srid to
Google srid.
It doesn't make sense.
On 20 May 2010 17:38, "Ronald Phillips" <rphillips at summitengineer.net>
wrote:
SELECT
ST_AsText(
ST_GeomFromText('POINT(-81.064544 40.28787)', 3857)
AS goog,
ST_AsText(
ST_Transform(
40.28787)', 3857)
, 4326)
AS gcs
3857 is “Google’s” SRID, and 4326 is a fairly standard GPS SRID. I’m getting
this:
Goog: "POINT(-81.064544 40.28787)";
Gcs: "POINT(-0.000728215188753794 0.000361912093851508)"
What am I doing wrong, that they’re so different?
Ronald Phillips, B.S., M.S.
Programmer/Analyst
Summit County Engineer
538 E. South St.
Akron OH 44311
330.643.8061
http://www.linkedin.com/in/rwphillips
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100520/500d3c93/attachment.html>
