[postgis-users] I can't make sense of this.
Paul Ramsey
pramsey at opengeo.org
Thu May 20 09:57:39 PDT 2010
3857 is a Mercator projection. Your coordinates are geographics. If
you mis-declare your SRS (as, in your case, declaring that geographics
are mercators) then transform will spit out funny numbers on the basis
of that initial mistake.
P
On Thu, May 20, 2010 at 9:38 AM, Ronald Phillips
<rphillips at summitengineer.net> wrote:
> SELECT
> ST_AsText(
> ST_GeomFromText('POINT(-81.064544 40.28787)', 3857)
> AS goog,
> ST_AsText(
> ST_Transform(
> 40.28787)', 3857)
> , 4326)
> AS gcs
> 3857 is “Google’s” SRID, and 4326 is a fairly standard GPS SRID. I’m getting
> this:
> Goog: "POINT(-81.064544 40.28787)";
> Gcs: "POINT(-0.000728215188753794 0.000361912093851508)"
> What am I doing wrong, that they’re so different?
> Ronald Phillips, B.S., M.S.
> Programmer/Analyst
> Summit County Engineer
> 538 E. South St.
> Akron OH 44311
> 330.643.8061
> http://www.linkedin.com/in/rwphillips
> postgis-users mailing list
