[postgis-users] PostGIS: make check works, but I can't manually create a spatial database
Peter Cotroneo geopetrus at gmail.com
Thu May 27 02:14:41 PDT 2010
Hi Devrim,
Thanks for your reply.  Here’s what I get immediately after trying to create
a spatial database:
[root at ip-10-224-82-127 postgis-1.5.0SVN]# sudo -u postgres createdb testdb
[root at ip-10-224-82-127 postgis-1.5.0SVN]# sudo -u postgres createlang
plpgsql testdb
[root at ip-10-224-82-127 postgis-1.5.0SVN]# sudo -u postgres psql -d testdb -f
postgis/postgis.sql
BEGIN
psql:postgis/postgis.sql:57: NOTICE:  type "spheroid" is not yet defined
DETAIL:  Creating a shell type definition.
CREATE FUNCTION
psql:postgis/postgis.sql:63: NOTICE:  argument type spheroid is only a shell
CREATE FUNCTION
psql:postgis/postgis.sql:68: NOTICE:  return type spheroid is only a shell
CREATE FUNCTION
psql:postgis/postgis.sql:73: NOTICE:  argument type spheroid is only a shell
CREATE FUNCTION
CREATE TYPE
psql:postgis/postgis.sql:90: NOTICE:  type "geometry" is not yet defined
As I mentioned yesterday, make check works just fine (i.e., it creates the
spatial database postgis_reg).
Cheers,
Petrus
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100527/9b4f1358/attachment.html>
