[postgis-users] PostGIS: make check works, but I can't manually create a spatial database
Kevin Neufeld
kneufeld at refractions.net
Thu May 27 20:47:07 PDT 2010
These are not the ERRORs messages Devrim was referring to. These are
merely NOTICEs that are typical for a PostGIS installation. Before all
the "ERROR: transaction was aborted" log entries you reported, there
should be a line that indicates what caused the transaction to roll back.
-- Kevin
On 5/27/2010 2:14 AM, Peter Cotroneo wrote:
> Hi Devrim,
> Thanks for your reply. Here’s what I get immediately after trying to
> create a spatial database:
> [root at ip-10-224-82-127 postgis-1.5.0SVN]# sudo -u postgres createdb testdb
> [root at ip-10-224-82-127 postgis-1.5.0SVN]# sudo -u postgres createlang
> plpgsql testdb
> [root at ip-10-224-82-127 postgis-1.5.0SVN]# sudo -u postgres psql -d
> testdb -f postgis/postgis.sql
> BEGIN
> psql:postgis/postgis.sql:57: NOTICE: type "spheroid" is not yet defined
> DETAIL: Creating a shell type definition.
> CREATE FUNCTION
> psql:postgis/postgis.sql:63: NOTICE: argument type spheroid is only a
> shell
> CREATE FUNCTION
> psql:postgis/postgis.sql:68: NOTICE: return type spheroid is only a shell
> CREATE FUNCTION
> psql:postgis/postgis.sql:73: NOTICE: argument type spheroid is only a
> shell
> CREATE FUNCTION
> CREATE TYPE
> psql:postgis/postgis.sql:90: NOTICE: type "geometry" is not yet defined
> As I mentioned yesterday, make check works just fine (i.e., it creates
> the spatial database postgis_reg).
> Cheers,
> Petrus
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100527/baec329c/attachment.html>
