[postgis-users] memory problems
Paul Ramsey
pramsey at opengeo.org
Thu Nov 11 07:49:32 PST 2010
Till,
Upgrade to 1.3.5 at least. There were massive memory leaks in comes
cases of point-in-polygon tests in the early 1.3 series.
P
On Thu, Nov 11, 2010 at 7:45 AM, Till Kirchner
<till.kirchner at vti.bund.de> wrote:
> Hi together,
> I have a memory problem when executing a Point-In-Polygon function.
> Actually I think it is a configuration problem.
> The executed query is:
> CREATE TABLE temp.tbl_c AS
> SELECT ...
> FROM
> tbl_b AS b,
> tbl_a AS a
> WHERE
> b.the_geom && a.the_geom AND ST_Within(b.the_geom, a.the_geom)
> The Log says following:
> -- LOG
> PortalMemory: 8192 total in 1 blocks; 8040 free (0 chunks); 152 used
> PortalHeapMemory: 1024 total in 1 blocks; 896 free (0 chunks); 128 used
> ExecutorState: 2085793336 total in 278 blocks; 26808 free (10 chunks);
> 2085766528 used
> -- identisch zur Fehlermeldung ErrorContext
> GiST temporary context: 8192 total in 1 blocks; 8176 free (0 chunks);
> 16 used
> ExprContext: 0 total in 0 blocks; 0 free (0 chunks); 0 used
> ExprContext: 40960 total in 3 blocks; 40912 free (21 chunks); 48 used
> ExprContext: 40960 total in 3 blocks; 32440 free (16 chunks); 8520
> used
> Relcache by OID: 8192 total in 1 blocks; 2856 free (0 chunks); 5336 used
> MdSmgr: 8192 total in 1 blocks; 7024 free (0 chunks); 1168 used
> LOCALLOCK hash: 8192 total in 1 blocks; 3912 free (0 chunks); 4280 used
> Timezones: 48616 total in 2 blocks; 5968 free (0 chunks); 42648 used
> ErrorContext: 8192 total in 1 blocks; 8176 free (0 chunks); 16 used
> 2010-11-11 11:48:33 : FEHLER: Speicher aufgebraucht
> 2010-11-11 11:48:33 : DETAIL: Fehler bei Anfrage mit Größe 16.
> 2010-11-11 11:48:33 : ANWEISUNG: CREATE TABLE ...
> So the system runs out of memory for a request of size 16?
> Frankly speaking I have no idea what that means.
> The values shown in the "ErrorContext" are repeated in "GiST temporary
> context".
> So I guess it's a problem about temporary files belonging to the used
> spatial indexes!?
> The tbl_a has a fulltblsize of 10165MB (POLYGONS (Index-toast-table:
> 1532MB)).
> The tbl_b has a fulltblsize of 47MB (POINTS (Index-toast-table: less than
> 1MB)).
> The Postgres-Version is: PostgreSQL 8.3.7 on i486-pc-linux-gnu, compiled by
> GCC gcc-4.3.real (Debian 4.3.3-5) 4.3.3
> The PostGIS-Version is: POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel.
> 4.6.1, 21 August 2008" USE_STATS
> The machine is a 32bit Debian with 4GB RAM.
> Main settings are:
> checkpoint_segments: 32
> checkpoint_timeout: 120s
> effective_cache_size: 2GB
> maintenance_work_mem: 200MB
> max_connections: 50
> max_fsm_pages: 153600
> shared_buffers: 131072 (1GB)
> wal_buffers: 16MB
> work_mem: 40MB
> Thanks for any help in adcvance
> Till
> postgis-users mailing list
