[postgis-users] Postgis & R language
Jan Hartmann
j.l.h.hartmann at uva.nl
Wed Nov 17 04:46:11 PST 2010
You could install rgdal in R and then use that R-version for PL/R
(http://cran.r-project.org/web/packages/rgdal/index.html) . It's a bit
round-about of course: do you use PostGIS from R, or R from PostGIS?
Jan
On 11/17/10 12:46, David Potts wrote:
> Hi List
> Has anybody ever tried to read the value of geometry column from a table
> into a R-language application using the plr handler, is this a support
> option?
> Thanks in advance.
> xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
> Any views expressed in this message are those of the individual sender,
> except where the sender specifically states them to be the views of the
> Pinan Software
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101117/da5e21ea/attachment.html>
