[postgis-users] Postgis & R language
David Potts dave.potts at pinan.co.uk
Wed Nov 17 05:09:35 PST 2010
I want to draw some graphs from an some data from a table that has
geometry column, before starting anything I wanted to ensure that the
software could handle it.
> You could install rgdal in R and then use that R-version for PL/R
> (http://cran.r-project.org/web/packages/rgdal/index.html) . It's a bit
> round-about of course: do you use PostGIS from R, or R from PostGIS?
> Jan
> On 11/17/10 12:46, David Potts wrote:
>> Hi List
>> Has anybody ever tried to read the value of geometry column from a table
>> into a R-language application  using the plr handler, is this a support
>> option?
>> Thanks in advance.
>> xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
>> Any views expressed in this message are those of the individual sender,
>> except where the sender specifically states them to be the views of the
>> Pinan Software
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Pinan Software
