[postgis-users] Postgis & R language
Jan Hartmann
j.l.h.hartmann at uva.nl
Wed Nov 17 06:22:20 PST 2010
You could do this completely within R by installing both rgdal and
rpostresql (http://code.google.com/p/rpostgresql/). You'll have to split
your queries in an attribute part (rpostgresql) and a geometry part
(rgdal, returning sp items) and combining them afterwards. I have never
done this but it should work. Moreover, one of the developers of
rpostgesql is Joe Conway, the maker of PL/R. He'll certainly anser
questions on the PL/R mailing list.
Jan
On 11/17/10 14:09, David Potts wrote:
> I want to draw some graphs from an some data from a table that has
> geometry column, before starting anything I wanted to ensure that the
> software could handle it.
>> You could install rgdal in R and then use that R-version for PL/R
>> (http://cran.r-project.org/web/packages/rgdal/index.html) . It's a bit
>> round-about of course: do you use PostGIS from R, or R from PostGIS?
>> Jan
>> On 11/17/10 12:46, David Potts wrote:
>>> Hi List
>>> Has anybody ever tried to read the value of geometry column from a table
>>> into a R-language application using the plr handler, is this a support
>>> option?
>>> Thanks in advance.
>>> xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
>>> Any views expressed in this message are those of the individual sender,
>>> except where the sender specifically states them to be the views of the
>>> Pinan Software
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Pinan Software
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101117/e27601c0/attachment.html>
