[postgis-users] Postgis & R language
pcreso at pcreso.com pcreso at pcreso.com
Wed Nov 17 10:24:16 PST 2010
Hi David,
You can use PL/R to access R functionality from a Postgres SQL command line, or you can use rgdal to read Postgis data into R.
So it depends on whether you want to work in the DB & add R capabilities, or work in R & access Postgis data.
See:
http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgresql_plr_tut01
http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgresql_plr_tut02
for a useful introduction to PL/R; and for rgdal, see:
http://rgdal.sourceforge.net/
http://cran.r-project.org/web/packages/rgdal/rgdal.pdf
http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgresql_plr_tut03
HTH,
  Brent Wood
--- On Thu, 11/18/10, David Potts <dave.potts at pinan.co.uk> wrote:
Subject: [postgis-users] Postgis & R language
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Date: Thursday, November 18, 2010, 12:46 AM
Hi List
Has anybody ever tried to read the value of geometry column from a table
into a R-language application  using the plr handler, is this a support
option?
Thanks in advance.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Any views expressed in this message are those of the individual sender,
except where the sender specifically states them to be the views of the
Pinan Software
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101117/5e134228/attachment.html>
