[postgis-users] export polygon to shapefile problem
Thomas Kouk
thomaskouk at yahoo.gr
Wed Nov 17 05:32:38 PST 2010
I left the -a_srs out and I no longer have the usage information, but instead I
have an error message:
ESRI Shapefile driver failed to create file.shp.
The same happens for other spatial tables as well (not necessarily polygons).
The table contains only a geometry column. The funny thing is that if I use a
script to merge a lot of such tables into one, adding a gid column so that I can
distinguish them, using the command I tried in the beginning:
pgsql2shp -P [password] -f [shapefile path & name] postgis [tablename]
works fine! However it would be stupid to create another script to split the
data and deal with this in this way.
From: Marco Lechner - FOSSGIS e.V. <marco.lechner at fossgis.de>
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Sent: Wed, November 17, 2010 12:44:19 PM
Subject: Re: [postgis-users] export polygon to shapefile problem
- you could leave out the -a_srs for testing
- it should be possible to use those table names like W_TQ2575_Buffer by masking
the "
Marco
Am 17.11.2010 13:40, schrieb Thomas Kouk:
Hi Marco,
>I tried the sql statement in psql, it works fine, no error message.
>There is no error message right above the usage information.
>I do not want to reproject, polygon is already in SRID 27700.
>The table's name could be the problem, because in pgadmin sql window or psql
>window it needs quotation (""). So I created a new table like the old one, only
>with a simpler name. I tried again, but still with no results:
>ogr2ogr -a -f "ESRI Shapefile" file.shp PG:"dbname=postgis host=localhost
>user=postgres password=postgres" -sql "SELECT AsBinary(the_geom) as wkb_geometry
>FROM test"
>Is there any other way?
>Thanks
>Sent: Wed, November 17, 2010 12:07:27 PM
>try
>C:\Program Files\FWTools2.4.7\bin>ogr2ogr -a srs "EPSG:27700" ...
>Does your sql-statemnet produce a result when executed within psql?
>Are you sure there's no error message right above the usage information?
>Do you want to reproject to 27700? Then you should use -t_srs
>Marco
>Am 17.11.2010 12:56, schrieb Thomas Kouk:
>Thanks Helen,
>>I've been trying to make it work. I don't have ogr2ogr.exe somewhere in
>>PostgreSQL folder. The only place where I have ogr2ogr.exe is in FWTools folder,
>>(other ones in OSGeo4W do not work, dll problems).
>>So I try this:
>>C:\Program Files\FWTools2.4.7\bin> ogr2ogr -a srs EPSG:27700 -f "ESRI Shapefile"
>>file.shp PG:"dbname=postgis host=localhost user=postgres password=postgres"
>>-sql "SELECT AsBinary(the_geom) as wkb_geometry FROM W_TQ2575_Buffer"
>>After this I do not get any error message, but I get the ogr2ogr usage
>>information (as if something I typed is wrong) and the file.shp is not created
>>(cannot be found anywhere).
>>Any help?
From: Helen San Segundo Navazo <hsansegundo at meteo.cat>
>>Sent: Wed, November 17, 2010 9:29:15 AM
>>Hi Thomas,
>>I use the next expression to export data automatically in an script from a table
>>with polygons into a shape file:
>>ogr2ogr -a_srs EPSG:23031 -f "ESRI Shapefile" file.shp PG:"dbname=db_name
>>host=the_host user=the_user password=the_password" -sql "SELECT
>>AsBinary(the_geometry_column) as wkb_geometry, column2,column3,column4 etc. FROM
>>table where conditions"
>>I hope this will help you,
>>Helen
>>Thomas Kouk escribió:
>>> Hi all,
>>> I am newbie in PostGIS and I have a problem exporting a polygon table in shp. I
>>>want to export specific spatial tables from by database using a batch procedure
>>>(bat file). The command I use is:
>>> pgsql2shp -P [password] -f [shapefile path & name] postgis [tablename], for
>>>example: pgsql2shp -P postgres -f Data\Buffers\ Buffer.shp postgis buffer_table
>>> It works fine with all other spatial tables (linestring or multilinestring
>>>type). For polygons it also seems to work, as I get no error message:
>>> / Initializing... Done (postgis major version: 1)./
>>> / Output shape: Polygon/
>>> / Dumping: XX [1 rows]./
>>> However, when I try to load the polygon shp in Qgis or ArcGIS I get an error:
>>>ArcGIS cannot open the file, while QGIS loads the shp but displays nothing (as
>>>if the table is empty, which is not the case).
>>> All my tables are spatial tables with no information on geometry_columns table,
>>>but even if I add the polygon table in the geometry_columns, nothing changes.
>>>After all, the function works with all other spatial non polygon tables despite
>>>the fact that geometry_columns holds no information on them, so this is not the
>>>problem.
>>> I can load the postgis polygon table in qgis and export it manually to a shp,
>>>which works fine, but I need to do it in an automatic way using a command.
>>> Has anyone come to this problem or is there something I do not know about
>>>exporting polygon tables to shp?
>>> Thanks.
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>http://www.meteo.cat
>>Tel. 93 567 60 90
>>Fax 93 567 61 02
>>A/e hsansegundo at meteo.cat <mailto:hsansegundo at meteo.cat>
>>Abans d’imprimir aquest correu, assegureu-vos que és del tot necessari. El medi
>>ambient és cosa de tothom!
>>La informació d'aquesta transmissió electrònica és confidencial i el seu ús sols
>>està permès als seus destinataris. Si Vostè no és la persona destinatària
>>d'aquesta transmissió electrònica, li preguem que ens ho comuniqui de forma
>>immediata i destrueixi qualsevol copia de la mateixa (tant digital com en
>>paper).
>> _______________________________________________ postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101117/4046581e/attachment.html>
