[postgis-users] export polygon to shapefile problem
Kevin Neufeld
kneufeld at refractions.net
Wed Nov 17 08:31:34 PST 2010
I suspect your merge process worked because you added an attribute
column (gid) to the exported geometries.
Try adding some attribute on the fly ... something like this:
pgsql2shp -f polys.shp postgis "SELECT null::char AS blank_attr,
the_geom FROM my_poly_table"
-- Kevin
On 11/17/2010 5:32 AM, Thomas Kouk wrote:
> I left the -a_srs out and I no longer have the usage information, but
> instead I have an error message:
> ESRI Shapefile driver failed to create file.shp.
> The same happens for other spatial tables as well (not necessarily
> polygons).
> The table contains only a geometry column. The funny thing is that if
> I use a script to merge a lot of such tables into one, adding a gid
> column so that I can distinguish them, using the command I tried in
> the beginning:
> pgsql2shp -P [password] -f [shapefile path & name] postgis [tablename]
> works fine! However it would be stupid to create another script to
> split the data and deal with this in this way.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101117/bfab9a5a/attachment.html>
