[postgis-users] spatial join nearest neighbor
Lazrak, F. (Faroek) flazrak at feweb.vu.nl
Thu Nov 18 01:37:34 PST 2010
I have a really simple problem but I am not able to solve the problem.
I have a point data and a have polygon data and I want to merge the data
of the polygon to the points based on the nearest distance to polygon.
The problem is that my point data is 2,5 million observations and the
polygon are approximately 700 observations resulting in 1,75 billion
rows where I have to minimize over 700.
Currently I have the following query:
SELECT
a.key,
b.gid,
st_distance(a.the_geom, b.the_geom) as dist,
s.min_dist
FROM
  Neighbor as b, point as a
LEFT JOIN
  (SELECT
     a.key, MIN(st_distance(a.the_geom, b.the_geom)) as min_dist
   FROM
   GROUP BY
     a.key) s
ON
  a."key" = S."key"
ORDER by a.key
This querty gives all the 1,75 billion possibilities which then can be
used to minimize over a.key restricted by dist=min_dist, the problem is
that by the first query the computer run out of memory, so the second
query is not working.
In arcgis the problem is joining by closed distance but I need to do it
in postgis.
Hope you can help my,
Faroek
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101118/086b635a/attachment.html>
