[postgis-users] spatial join nearest neighbor
ByronCinNz
byron.cochrane at lisasoft.com
Thu Nov 18 13:05:56 PST 2010
Hello,
This link might provide the solution you need. I am using this for a similar
issue to yours with good results.
http://www.bostongis.com/?content_name=postgis_nearest_neighbor_generic
Cheers,
Byron
Lazrak, F. (Faroek) wrote:
> Hi,
> I have a really simple problem but I am not able to solve the problem.
> I have a point data and a have polygon data and I want to merge the data
> of the polygon to the points based on the nearest distance to polygon.
> The problem is that my point data is 2,5 million observations and the
> polygon are approximately 700 observations resulting in 1,75 billion
> rows where I have to minimize over 700.
> Currently I have the following query:
> SELECT
> a.key,
> b.gid,
> st_distance(a.the_geom, b.the_geom) as dist,
> s.min_dist
> FROM
> Neighbor as b, point as a
> LEFT JOIN
> (SELECT
> a.key, MIN(st_distance(a.the_geom, b.the_geom)) as min_dist
> FROM
> GROUP BY
> a.key) s
> ON
> a."key" = S."key"
> ORDER by a.key
> This querty gives all the 1,75 billion possibilities which then can be
> used to minimize over a.key restricted by dist=min_dist, the problem is
> that by the first query the computer run out of memory, so the second
> query is not working.
> In arcgis the problem is joining by closed distance but I need to do it
> in postgis.
> Hope you can help my,
> Faroek
> postgis-users mailing list
View this message in context: http://old.nabble.com/spatial-join-nearest-neighbor-tp30246195p30252222.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
