[postgis-users] Query to select dangling line segments
Brian Stempin
brian.stempin at gmail.com
Tue Nov 30 14:34:45 PST 2010
So, I decided to run with the following query:
SELECT osm_id
FROM "OSMData".osm_mn_data_highway_20101129_101234 t1
WHERE osm_id NOT IN (
-- list all ids where the startpoint intersects something.
SELECT t1.osm_id
FROM "OSMData".osm_mn_data_highway_20101129_101234 t1,
"OSMData".osm_mn_data_highway_20101129_101234 t2
WHERE t1.osm_id <> t2.osm_id
AND ST_Intersects(ST_StartPoint(t1.way), t2.way)
UNION
SELECT osm_id
SELECT t1.osm_id
AND ST_Intersects(ST_EndPoint(t1.way), t2.way)
In my dataset, this takes ~ 8 seconds to run. Being a bit of a performance
junkee, I modified it to the following:
SELECT osm_id, ST_StartPoint(way)
SELECT t1.osm_id
AND t2.way ~ t1.way
UNION
SELECT osm_id, ST_EndPoint(way)
SELECT t1.osm_id
AND t2.way ~ t1.way
Note the addition of the "t2.way ~ t1.way" bit. "A ~ B" means "A's bounding
box contains B's bounding box." Since in my case B is a point, I eliminate
a lot of comparisons by only looking at shapes who's bounding box B is
contained in. This reduced my query time from 8.x seconds to 3.4x seconds.
Thanks a ton, Kevin!
Brian
PS -- anyone else spot any other improvements that I can make? I plan on
writing about this in a blog article as part of a larger piece later
tonight/tomorrow.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101130/4da3ef3d/attachment.html>
