[postgis-users] Query to select dangling line segments
Kevin Neufeld
kneufeld.ca at gmail.com
Tue Nov 30 19:32:45 PST 2010
Glad you got it working.
Just a little note of warning ... I noticed you are using "UNION", not
"UNION ALL". The difference is that the later will perform a simple
concatenation of the two results sets. The former is kind of like a set
union, returning results that are in the first or second query, removing
duplicate rows. In your 8 second query, not a big deal, but in your 3
second query, you've include a geometry object. In determining record
equivalence to filter duplicate rows, it is the = operator that is
invoked against two geometry objects, which goes back to comparing
bounding box equivalence, not geometry equivalence.
i.e.
SELECT 'POINT(0 0)'::geometry
UNION
SELECT 'POINT(0 0.0000001)'::geometry;
geometry
010100000000000000000000000000000000000000
(1 row)
UNION ALL
geometry
0101000000000000000000000048AFBC9AF2D77A3E
(2 rows)
Not a big deal, but I just wanted to make sure you knew what was
happening with your query.
UNION ALL should also be faster as it's not trying to merge two results
sets together.
Cheers,
Kevin
On 11/30/2010 2:34 PM, Brian Stempin wrote:
> So, I decided to run with the following query:
> SELECT osm_id
> FROM "OSMData".osm_mn_data_highway_20101129_101234 t1
> WHERE osm_id NOT IN (
> -- list all ids where the startpoint intersects something.
> SELECT t1.osm_id
> FROM "OSMData".osm_mn_data_highway_20101129_101234 t1,
> "OSMData".osm_mn_data_highway_20101129_101234 t2
> WHERE t1.osm_id <> t2.osm_id
> AND ST_Intersects(ST_StartPoint(t1.way), t2.way)
> UNION
> SELECT osm_id
> SELECT t1.osm_id
> AND ST_Intersects(ST_EndPoint(t1.way), t2.way)
> In my dataset, this takes ~ 8 seconds to run. Being a bit of a
> performance junkee, I modified it to the following:
> SELECT osm_id, ST_StartPoint(way)
> SELECT t1.osm_id
> AND t2.way ~ t1.way
> UNION
> SELECT osm_id, ST_EndPoint(way)
> SELECT t1.osm_id
> AND t2.way ~ t1.way
> Note the addition of the "t2.way ~ t1.way" bit. "A ~ B" means "A's
> bounding box contains B's bounding box." Since in my case B is a
> point, I eliminate a lot of comparisons by only looking at shapes
> who's bounding box B is contained in. This reduced my query time from
> 8.x seconds to 3.4x seconds.
> Thanks a ton, Kevin!
> Brian
> PS -- anyone else spot any other improvements that I can make? I plan
> on writing about this in a blog article as part of a larger piece
> later tonight/tomorrow.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101130/f375198e/attachment.html>
