[postgis-users] Hanging Postgres 9.0 + Postgis 1.5.2 on windows
Andrea Peri 2007
aperi2007 at gmail.com
Sat Oct 2 16:03:25 PDT 2010
I've test again.
>I guess to rule out PostGIS as the culprit -- you could try upgrading your
>Postgres 8.4.4 to 1.5.2 (a quick way is to copy over the postgis-1.5.dll
>,libxml, and geos binaries in bin folde) -- making sure to backup your
>existing and restart. Binaries are available Postgis 1.5 8.4 binaries.
>http://www.postgis.org/download/windows/#windbinaries
The execution of the script on the PG8.4.4 with Postgis 1.5.2 terminate
without any problem.
As more test,
I try to re-install PG9.0 + Postgis 1.5.2.
But without any result.
PG 9.0 crash again with that script sql.
Regards,
Andrea.
