[postgis-users] KML to PostGIS
Olivier Courtin
olivier.courtin at oslandia.com
Mon Oct 4 05:49:16 PDT 2010
On Oct 4, 2010, at 2:40 PM, Paulo Angelo wrote:
> Now I'm getting another problem, look below. Is there anything I can
> do?
> $ ogrinfo doc.kml
> ERROR 4: No layers in KML file: doc.kml.
Look like there's a problem with your KML file
You could first check against KML schema:
xmllint --schema http://schemas.opengis.net/kml/2.2.0/ogckml22.xsd
doc.kml
And if your document is valid, ask on gdal list to get further help
Olivier
