[postgis-users] KML to PostGIS
Paulo Angelo
pa at pauloangelo.com
Mon Oct 4 10:57:41 PDT 2010
Hi Oliver,
Thank you for help...
[]'s
PA
On Mon, Oct 4, 2010 at 9:49 AM, Olivier Courtin <
olivier.courtin at oslandia.com> wrote:
> On Oct 4, 2010, at 2:40 PM, Paulo Angelo wrote:
> Now I'm getting another problem, look below. Is there anything I can do?
>> $ ogrinfo doc.kml
>> ERROR 4: No layers in KML file: doc.kml.
> Look like there's a problem with your KML file
> You could first check against KML schema:
> xmllint --schema http://schemas.opengis.net/kml/2.2.0/ogckml22.xsd doc.kml
> And if your document is valid, ask on gdal list to get further help
> Olivier
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101004/d7cdeaac/attachment.html>
