[postgis-users] working with multipolygons
lplateandy
andy at centremaps.co.uk
Fri Oct 8 14:11:24 PDT 2010
Looking for some tips about the right direction to take when tidying up some
multi-polygon data. I
have lots of 2 by 2 kilometre chunks defining a type of coverage.
The information for each 2 by 2km chunk has been merged into multi-polygons,
it may have holes as small as 25 by 25 metres or equally the area may only
be partly filled along with little 25 by 25 metre islands.
Is there a method to delete parts of a multi-polygon for example:
1) Any elements which represent a hole
2) Any elements below a certain threshold size
I can imagine that dissolving the multi-polygon would allow me to apply
changes to the islands but am not sure about the holes
I also found that when i tried to carry out some queries such as
ST_SimplifyPreserveTopology or ST_Envelope i get null areas or bounding
boxes of just one of the holes - as though the action is just being applied
to one of the elements in the polygon - perhaps the first one - is that the
case?
Any pointers to get me started would be much appreciated.
Thanks in advance
Andy
View this message in context: http://old.nabble.com/working-with-multipolygons-tp29919084p29919084.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
