[postgis-users] working with multipolygons
Simon Greener
simon at spatialdbadvisor.com
Fri Oct 8 16:08:53 PDT 2010
Andy,
Is this of any use to you:
http://www.spatialdbadvisor.com/postgis_tips_tricks/92/filtering-rings-in-polygon-postgis
regards
Simon
On Sat, 09 Oct 2010 08:11:24 +1100, lplateandy <andy at centremaps.co.uk> wrote:
> Hi,
> Looking for some tips about the right direction to take when tidying up some
> multi-polygon data. I
> have lots of 2 by 2 kilometre chunks defining a type of coverage.
> The information for each 2 by 2km chunk has been merged into multi-polygons,
> it may have holes as small as 25 by 25 metres or equally the area may only
> be partly filled along with little 25 by 25 metre islands.
> Is there a method to delete parts of a multi-polygon for example:
> 1) Any elements which represent a hole
> 2) Any elements below a certain threshold size
> I can imagine that dissolving the multi-polygon would allow me to apply
> changes to the islands but am not sure about the holes
> I also found that when i tried to carry out some queries such as
> ST_SimplifyPreserveTopology or ST_Envelope i get null areas or bounding
> boxes of just one of the holes - as though the action is just being applied
> to one of the elements in the polygon - perhaps the first one - is that the
> case?
> Any pointers to get me started would be much appreciated.
> Thanks in advance
> Andy
SpatialDB Advice and Design, Solutions Architecture and Programming,
Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, FME, Radius Topology and Studio Specialist.
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
Website: www.spatialdbadvisor.com
Email: simon at spatialdbadvisor.com
Voice: +61 362 396397
Mobile: +61 418 396391
Skype: sggreener
Longitude: 147.20515 (147° 12' 18" E)
Latitude: -43.01530 (43° 00' 55" S)
GeoHash: r22em9r98wg
NAC:W80CK 7SWP3
