[postgis-users] error with a $libdir variable defined in postgis.sql
Andrea Peri 2007 aperi2007 at gmail.com
Mon Oct 11 15:22:45 PDT 2010
>hi all,
>i have downloaded the binaries for windows 32bit : postgis-pg90-binaries-2.0svn
>when i proceed to run the batch file, this error appears and the whole
>process goes wrong:
>SET
>BEGIN
>psql:share/contrib/postgis-2.0/postgis.sql:59: ERROR:  could not
>access file "$libdir/postgis-2.0": No such file or directory
>any help would be appreciated
>Victor
Have you modify the batch file "makepostgisdb.bat" for your configuration ?
Is necessary to set two variables with the right paths,
like this:
set PGBIN=C:\Program Files (x86)\PostgreSQL\9.0\bin\
set PGLIB=C:\Program Files (x86)\PostgreSQL\9.0\lib\
Regards,
Andrea Peri
