[postgis-users] Out of memory error with BOX3D
Jan Saalbach fire at dubmosphere.de
Wed Oct 20 05:21:33 PDT 2010
Hi all,
an "out of memory error" occurs when I issue the following command:
SELECT BOX3D(ST_COLLECT(punkte)) FROM rohdaten WHERE id=109;
"punkte" is a GeometryColumn filled with POINT3D, 17 million for id=109.
The machine has 4GB of ram.
I chose the box3d over the ConvexHull function because I thought it
would be much faster, and much less memory consuming. Apparently I was
wrong about memory consuming.
What I do not get is why a computation as simple as "min x,y,z and max
x,y,z all at once" should consume that much memory. Can someone explain
to me what point I am missing?
Issuing MIN(ST_X... MIN(ST_Y... commands one after another works fine
and is quite fast.
Regards,
Jan
