[postgis-users] Out of memory error with BOX3D
Nicklas Avén
nicklas.aven at jordogskog.no
Wed Oct 20 05:50:04 PDT 2010
Try St_Extent3D instead without st_collect. Then PostGIS can handle 1 point at a time and not all the 17 millions. So try:SELECT ST_Extent3D(punkte) FROM rohdaten WHERE id=109;
ConvexHull is only working in 2D. It will keep the third dimension but not include it in the calculations (not 100% sure about that, but almost) HTH Nicklas
2010-10-20 Jan Saalbach wrote:
Hi all,
>an "out of memory error" occurs when I issue the following command:
>SELECT BOX3D(ST_COLLECT(punkte)) FROM rohdaten WHERE id=109;
>"punkte" is a GeometryColumn filled with POINT3D, 17 million for id=109.
>The machine has 4GB of ram.
>I chose the box3d over the ConvexHull function because I thought it
>would be much faster, and much less memory consuming. Apparently I was
>wrong about memory consuming.
>What I do not get is why a computation as simple as "min x,y,z and max
>x,y,z all at once" should consume that much memory. Can someone explain
>to me what point I am missing?
>Issuing MIN(ST_X... MIN(ST_Y... commands one after another works fine
>and is quite fast.
>Regards,
>Jan
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101020/c8cad98e/attachment.html>
