[postgis-users] pgsql2shp dbf file encoding
Paul Ramsey
pramsey at opengeo.org
Mon Oct 25 10:30:36 PDT 2010
Can you hexedit it and see if it works better?
On Mon, Oct 25, 2010 at 10:25 AM, Denis Rykov <rykovd at gmail.com> wrote:
> Will it make sense to set 0 as a default? In the current case some software
> (ArcGIS) does not override correct CPG setting with obviously incorrect 1252
> from the header.
> On Tue, Oct 26, 2010 at 12:03 AM, Paul Ramsey <pramsey at opengeo.org> wrote:
>> And that DBF field dates from the Time Before UTF-8, so there won't be
>> a "UTF8" number to put in it, in any event. DBF files with UTF in
>> them (OSM!) are scary scary scary (for example, should your code for
>> reading a CHAR(8) field in DBF expect 8 bytes, or 8 characters? yay!)
>> It would be nice to support transcoding down to the code pages that
>> *are* supported in that field, I suppose. I wonder how much software
>> actually supports it.
>> P.
>> On Mon, Oct 25, 2010 at 9:57 AM, Mark Cave-Ayland
>> <mark.cave-ayland at siriusit.co.uk> wrote:
>> > Denis Rykov wrote:
>> >> I don't quite understand why pgsql2shp is writing this encoding to our
>> >> shapes, our database is in UTF-8 and we never use win1252
>> > Well pgsql2shp has never contained any code to set the encoding field
>> > (mainly because until recently the version of shapelib included with
>> > PostGIS
>> > didn't support the encoding field), so I guess WIN1252 must be the
>> > shapelib
>> > default.
>> > ATB,
>> > Mark.
>> > Mark Cave-Ayland - Senior Technical Architect
>> > PostgreSQL - PostGIS
>> > Sirius Corporation plc - control through freedom
>> > http://www.siriusit.co.uk
>> > t: +44 870 608 0063
>> > Sirius Labs: http://www.siriusit.co.uk/labs
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
