[postgis-users] pgsql2shp dbf file encoding
Denis Rykov
rykovd at gmail.com
Mon Oct 25 10:25:35 PDT 2010
Will it make sense to set 0 as a default? In the current case some software
(ArcGIS) does not override correct CPG setting with obviously incorrect 1252
from the header.
On Tue, Oct 26, 2010 at 12:03 AM, Paul Ramsey <pramsey at opengeo.org> wrote:
> And that DBF field dates from the Time Before UTF-8, so there won't be
> a "UTF8" number to put in it, in any event. DBF files with UTF in
> them (OSM!) are scary scary scary (for example, should your code for
> reading a CHAR(8) field in DBF expect 8 bytes, or 8 characters? yay!)
> It would be nice to support transcoding down to the code pages that
> *are* supported in that field, I suppose. I wonder how much software
> actually supports it.
> P.
> On Mon, Oct 25, 2010 at 9:57 AM, Mark Cave-Ayland
> <mark.cave-ayland at siriusit.co.uk> wrote:
> > Denis Rykov wrote:
> >> I don't quite understand why pgsql2shp is writing this encoding to our
> >> shapes, our database is in UTF-8 and we never use win1252
> > Well pgsql2shp has never contained any code to set the encoding field
> > (mainly because until recently the version of shapelib included with
> PostGIS
> > didn't support the encoding field), so I guess WIN1252 must be the
> shapelib
> > default.
> > ATB,
> > Mark.
> > Mark Cave-Ayland - Senior Technical Architect
> > PostgreSQL - PostGIS
> > Sirius Corporation plc - control through freedom
> > http://www.siriusit.co.uk
> > t: +44 870 608 0063
> > Sirius Labs: http://www.siriusit.co.uk/labs
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101026/112e0f32/attachment.html>
