[postgis-users] make comments failing
Dharmendra Goyal dharmendra.goyal at enterprisedb.com
Wed Oct 27 01:45:29 PDT 2010
I am able to make and 'make install' postgis sources on Winwos but when i
run 'make comments', it shows following error:
make comments
/bin/make -C doc comments
make[1]: Entering directory `/c/pginstaller.pune-repo/postgis.windows/doc'
./xsl/postgis_comments.sql.xsl postgis.xml > postgis_comments.sql
./xsl/postgis_comments.sql.xsl: line 1: syntax error near unexpected token
`newline'
./xsl/postgis_comments.sql.xsl: line 1: `<?xml version="1.0"
encoding="utf-8"?>'
make[1]: *** [postgis_comments.sql] Error 2
make[1]: Leaving directory `/c/pginstaller.pune-repo/postgis.windows/doc'
make: *** [comments] Error 2
Is it a know issue..??
Thanks,
Dharmendra
Dharmendra Goyal
Senior Software Engineer
EnterpriseDB Corporation
The Enterprise Postgres Company
Phone: +91-20-30589493
Mobile: +91-9552103323
Website: http://www.enterprisedb.com
EnterpriseDB Blog: http://blogs.enterprisedb.com/
Follow us on Twitter: http://www.twitter.com/enterprisedb
This e-mail message (and any attachment) is intended for the use of the
individual or entity to whom it is addressed. This message contains
information from EnterpriseDB Corporation that may be privileged,
confidential, or exempt from disclosure under applicable law. If you are not
the intended recipient or authorized to receive this for the intended
recipient, any use, dissemination, distribution, retention, archiving, or
copying of this communication is strictly prohibited. If you have received
this e-mail in error, please notify the sender immediately by reply e-mail
and delete this message.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101027/dde530b3/attachment.html>
