[postgis-users] make comments failing
Paragon Corporation
lr at pcorp.us
Wed Oct 27 15:02:27 PDT 2010
Dharmendra,
Which version are you compiling against -- 1.5? I may need to port my fix
to 1.5 but didn't since I wasn't sure it wouldn't cause other problems.
I got that error too for the postgis 2.0 when calling make comments under
MingW and removed the utf-8 stuff.
Before I would just make the comments using a made up script I had so didn't
notice this error under windows before.
It should be fixed in postgis 2.0.
FWIW: You really don't need to make the comments since they are packaged
with the postgis tar source ball.
Thanks,
Regina
h <http://www.postgis.us> ttp://www.postgis.us
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Dharmendra Goyal
Sent: Wednesday, October 27, 2010 4:45 AM
To: PostGIS Users Discussion
Subject: [postgis-users] make comments failing
I am able to make and 'make install' postgis sources on Winwos but when i
run 'make comments', it shows following error:
make comments
/bin/make -C doc comments
make[1]: Entering directory `/c/pginstaller.pune-repo/postgis.windows/doc'
./xsl/postgis_comments.sql.xsl postgis.xml > postgis_comments.sql
./xsl/postgis_comments.sql.xsl: line 1: syntax error near unexpected token
`newline'
./xsl/postgis_comments.sql.xsl: line 1: `<?xml version="1.0"
encoding="utf-8"?>'
make[1]: *** [postgis_comments.sql] Error 2
make[1]: Leaving directory `/c/pginstaller.pune-repo/postgis.windows/doc'
make: *** [comments] Error 2
Is it a know issue..??
Thanks,
Dharmendra
Dharmendra Goyal
Senior Software Engineer
EnterpriseDB Corporation
The Enterprise Postgres Company
Phone: +91-20-30589493
Mobile: +91-9552103323
Website: http://www.enterprisedb.com
EnterpriseDB Blog: http://blogs.enterprisedb.com/
Follow us on Twitter: http://www.twitter.com/enterprisedb
This e-mail message (and any attachment) is intended for the use of the
individual or entity to whom it is addressed. This message contains
information from EnterpriseDB Corporation that may be privileged,
confidential, or exempt from disclosure under applicable law. If you are not
the intended recipient or authorized to receive this for the intended
recipient, any use, dissemination, distribution, retention, archiving, or
copying of this communication is strictly prohibited. If you have received
this e-mail in error, please notify the sender immediately by reply e-mail
and delete this message.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101027/d6624bad/attachment.html>
