[postgis-users] make comments failing
Dharmendra Goyal
dharmendra.goyal at enterprisedb.com
Thu Oct 28 01:35:30 PDT 2010
Thanks for your reply.
I was using Postgis-1.5.2.
Regards,
On Thu, Oct 28, 2010 at 3:32 AM, Paragon Corporation <lr at pcorp.us> wrote:
> Dharmendra,
> Which version are you compiling against -- 1.5? I may need to port my fix
> to 1.5 but didn't since I wasn't sure it wouldn't cause other problems.
> I got that error too for the postgis 2.0 when calling make comments under
> MingW and removed the utf-8 stuff.
> Before I would just make the comments using a made up script I had so
> didn't notice this error under windows before.
> It should be fixed in postgis 2.0.
> FWIW: You really don't need to make the comments since they are packaged
> with the postgis tar source ball.
> Thanks,
> Regina
> http://www.postgis.us
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Dharmendra
> Goyal
> *Sent:* Wednesday, October 27, 2010 4:45 AM
> *To:* PostGIS Users Discussion
> *Subject:* [postgis-users] make comments failing
> Hi,
> I am able to make and 'make install' postgis sources on Winwos but when i
> run 'make comments', it shows following error:
> make comments
> /bin/make -C doc comments
> make[1]: Entering directory `/c/pginstaller.pune-repo/postgis.windows/doc'
> ./xsl/postgis_comments.sql.xsl postgis.xml > postgis_comments.sql
> ./xsl/postgis_comments.sql.xsl: line 1: syntax error near unexpected token
> `newline'
> ./xsl/postgis_comments.sql.xsl: line 1: `<?xml version="1.0"
> encoding="utf-8"?>'
> make[1]: *** [postgis_comments.sql] Error 2
> make[1]: Leaving directory `/c/pginstaller.pune-repo/postgis.windows/doc'
> make: *** [comments] Error 2
> Is it a know issue..??
> Thanks,
> Dharmendra
> Dharmendra Goyal
> Senior Software Engineer
> EnterpriseDB Corporation
> The Enterprise Postgres Company
> Phone: +91-20-30589493
> Mobile: +91-9552103323
> Website: http://www.enterprisedb.com
> EnterpriseDB Blog: http://blogs.enterprisedb.com/
> Follow us on Twitter: http://www.twitter.com/enterprisedb
> This e-mail message (and any attachment) is intended for the use of the
> individual or entity to whom it is addressed. This message contains
> information from EnterpriseDB Corporation that may be privileged,
> confidential, or exempt from disclosure under applicable law. If you are not
> the intended recipient or authorized to receive this for the intended
> recipient, any use, dissemination, distribution, retention, archiving, or
> copying of this communication is strictly prohibited. If you have received
> this e-mail in error, please notify the sender immediately by reply e-mail
> and delete this message.
> postgis-users mailing list
Dharmendra Goyal
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101028/2d8a5dd3/attachment.html>
