[postgis-users] Selecting polygons circled by one only polygons
Randall, Eric
ERandall at eriecountygov.org
Thu Oct 28 05:47:37 PDT 2010
You could try making a polygon out of the interior ring and using that with a within or contains:
st_buildarea(st_interiorringn(geometryn(geom,1),1))
-Eric
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Andrea Peri
Sent: Thursday, October 28, 2010 6:07 AM
To: PostGIS Users Discussion
Subject: [postgis-users] Selecting polygons circled by one only polygons
I have a table of polygon where every polygon can be holed.
And in the hole can be inside another polygon (another record of the table, no multipolygons).
I need to detect all the polygon that are inside a hole of another polygon.
Initially I think this was easy but
after some test I notice this is not so easy because the polygon inside the hole is formerly disjoint from the polygon with hole.
For more example I don't search the polygon that are full circled by more than 1 polygon, but only the polygon circled by 1 only polygon
There is some method to detect this type of situations ?
Thx,
Andrea peri.
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101028/d0e9c836/attachment.html>
