[postgis-users] Selecting polygons circled by one only polygons
pcreso at pcreso.com pcreso at pcreso.com
Thu Oct 28 10:09:08 PDT 2010
If I understand the question correctly, you want to identify polygons which are outside of a polygon (including inside the hole of another polygon) but within the outer polygon perimeter.
You can do this with a self relation (join a table to itself). Something like:
select t1.name from table t1, table t2
where not ST-Within (t1.geom, t2.geom)
    and ST_Within(t1.geom, ST_Boundary(t2.geom));
To get the count of these, rather than the list of names, try:
select count(t1.name) from table t1, table t2
HTH,
 Brent Wood
Sent: Thursday, October 28, 2010 6:07
  AM
To: PostGIS Users Discussion
Subject: [postgis-users]
  polygons
I have a table of polygon where every
  polygon can be holed.
And in the hole can be inside another polygon
  (another record of the table, no multipolygons).
I need to detect all
  the polygon that are inside a hole of another polygon.
Initially I
  think this was easy but
after some test I notice this is not so easy
  because the polygon inside the hole is formerly disjoint from the polygon with
  hole.
For more example I don't search the polygon that are full circled
  by more than 1 polygon, but only the polygon circled by 1 only
  polygon
There is some method to detect this type of situations
Thx,
Andrea peri.
Andrea Peri
qwerty
  àèìòù
-----Inline Attachment Follows-----
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101028/d853d972/attachment.html>
