[postgis-users] ST_AsBinary
Paragon Corporation
lr at pcorp.us
Sun Oct 31 09:53:40 PDT 2010
Mike,
Thanks for the tip. Is there any way to render the Z coordinates aside from
the info panel. We don't have too many 3 D examples in the book (and much
of the book is already finalized), but in the PostGIS Raster chapter we are
in the middle of rewriting we do have an example that converts a 2-D
linestring into a 3 D linestring by intersecting with Raster elevation data.
Would be nice to have a 3D representation of it.
Thanks,
Leo and Regina
http://www.postgis.us
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Michaël
Michaud
Sent: Sunday, October 31, 2010 11:52 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] ST_AsBinary
Thanks for the link. Very interesting faq indeed.
If you think it can be useful for the faq or for your book, I suggest to add
examples using As_EWKB instead of As_Binary to get data from PostGIS with
OpenJUMP as it seems to be the way to go not to loose z ordinates.
Michaël
Le 31/10/2010 04:03, Paragon Corporation a écrit :
Correct. In fact we even has this as our #1 FAQ for 1.5
http://www.postgis.org/documentation/manual-1.5SVN/ch03.html#id2872420
Thanks,
Regina and Leo
_____
Michaud
Sent: Saturday, October 30, 2010 4:54 PM
Hi Ravi,
Did you try to update your jdbc driver ?
Again, there is a link here to download it :
http://jdbc.postgresql.org/download.html
You should download
http://jdbc.postgresql.org/download/postgresql-9.0-801.jdbc3.jar
<http://jdbc.postgresql.org/download/postgresql-9.0-801.jdbc4.jar>
Then, you have to go in your OpenJUMP intallation directory and replace
postgresql-8.3-603.jdbc3.jar
by
If you're using java6, you should be able to use 9.0-801 JDBC 4
<http://jdbc.postgresql.org/download/postgresql-9.0-801.jdbc4.jar> instead
of 9.0-801 JDBC 3
Note that I haven't yet install postgresql 9.0 to check everything is fine,
but it comes from a discussion I had with postgis developpers that something
changed in the postgresql 9.0 byte array format, which is the reason why a
new driver is required.
Hope that helps
Michaël
Le 30/10/2010 21:06, Ravi a écrit :
ST_AsBinary
Other that OpenJUMP, suggest which FOSS4G tool can be used.
Finding some road blocks using
PostGIS and Seeing it on OpenJUMP.
Ravi Kumar
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101031/579b93c2/attachment.html>
