[postgis-users] ST_AsBinary
Michaël Michaud
michael.michaud at free.fr
Sun Oct 31 10:10:07 PDT 2010
There is not much functions in OpenJUMP to use Z ordinates, but you can
render them with the following decorations styles :
- Z vertex
- Segment downhill ...
Regards,
Michaël
Le 31/10/2010 17:53, Paragon Corporation a écrit :
> Mike,
> Thanks for the tip. Is there any way to render the Z coordinates
> aside from the info panel. We don't have too many 3 D examples in the
> book (and much of the book is already finalized), but in the PostGIS
> Raster chapter we are in the middle of rewriting we do have an example
> that converts a 2-D linestring into a 3 D linestring by intersecting
> with Raster elevation data. Would be nice to have a 3D representation
> of it.
> Thanks,
> Leo and Regina
> http://www.postgis.us
> *From:* postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of
> *Michaël Michaud
> *Sent:* Sunday, October 31, 2010 11:52 AM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] ST_AsBinary
> Hi,
> Thanks for the link. Very interesting faq indeed.
> If you think it can be useful for the faq or for your book, I suggest
> to add examples using As_EWKB instead of As_Binary to get data from
> PostGIS with OpenJUMP as it seems to be the way to go not to loose z
> ordinates.
> Michaël
> Le 31/10/2010 04:03, Paragon Corporation a écrit :
>> Correct. In fact we even has this as our #1 FAQ for 1.5
>> http://www.postgis.org/documentation/manual-1.5SVN/ch03.html#id2872420
>> Thanks,
>> Regina and Leo
>> *Michaël Michaud
>> *Sent:* Saturday, October 30, 2010 4:54 PM
>> Hi Ravi,
>> Did you try to update your jdbc driver ?
>> Again, there is a link here to download it :
>> http://jdbc.postgresql.org/download.html
>> You should download
>> http://jdbc.postgresql.org/download/postgresql-9.0-801.jdbc3.jar
>> <http://jdbc.postgresql.org/download/postgresql-9.0-801.jdbc4.jar>
>> Then, you have to go in your OpenJUMP intallation directory and replace
>> postgresql-8.3-603.jdbc3.jar
>> by
>> If you're using java6, you should be able to use 9.0-801 JDBC 4
>> instead of 9.0-801 JDBC 3
>> Note that I haven't yet install postgresql 9.0 to check everything is
>> fine, but it comes from a discussion I had with postgis developpers
>> that something changed in the postgresql 9.0 byte array format, which
>> is the reason why a new driver is required.
>> Hope that helps
>> Michaël
>> Le 30/10/2010 21:06, Ravi a écrit :
>>> ST_AsBinary
>>> Other that OpenJUMP, suggest which FOSS4G tool can be used.
>>> Finding some road blocks using
>>> PostGIS and Seeing it on OpenJUMP.
>>> Ravi Kumar
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101031/b1e0166d/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101031/b1e0166d/attachment.png>
