[postgis-users] Errors upgrading from 1.4.0 to 1.5.2
David Cato
otac at crunchyfrog.net
Sun Oct 31 22:13:33 PDT 2010
Paragon Corporation wrote ...
> My guess is that you probably have some sql functions using the old
> deprecated Extent aggregate so it can't be cleanly dropped and unfortunately
> there is no ALTER AGGREGATE function in PostgreSQL yet.
> What you can do is one of 3 things that come to mind
> 1) Find the code and change it to use ST_Extent. This is probalby in an SQL
> function since PostgreSQL is not smart enough in 8.4 to check the internals
> of plpgsql. If you are using pgAdminIII it shows
> The dependents of each function in one of the tabs..
> 2) Do a Hard upgrade -- by that I mean what Paul has described here -
> http://blog.cleverelephant.ca/2010/09/postgis-back-up-restore.html
> Or
> 3) If your database is too big to go thru that trouble
> Just remark out the DROP/CREATE AGGREGATE of the deprecated functions. And
> hmm deal with it later. Those will still work anyway.
> If you get an error with ST_Extent (I actually don't think that has changed
> signature between 1.4 and 1.5 so you can probably safely remark that out
> too.)
Thanks for the quick reply.
I couldn't find anything that was using the old Extent aggregate so I
opted for the hard upgrade approach and everything seems to be working
fine.
David Cato
