[postgis-users] Size of .dbf file produced with pgsql2shp
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Wed Sep 1 10:29:56 PDT 2010
strk wrote:
>> Checking the resulting file size is not the right way to be trying to
>> detect whether the query returned > 0 rows. It strikes me that the best
>> way to detect this would be to return a different exit code from
>> pgsql2shp if no rows are returned - would this work for you?
> I'd go stricter to "if an ERROR occurred" rather than
> "if no rows are returned".
> Just in case one day we'll add a flag to specify the geometry type
> thus allowing creation of empty-but-structuted shapefiles starting
> from a table "template".
> --strk;
This is exactly how the new code in trunk currently works - you get an
exit code of 0 to indicate success, and an exit code of 1 if an error
occurred. I was thinking of adding a new exit code of 2 to indicate
success, but also that 0 records were processed.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
