[postgis-users] Size of .dbf file produced with pgsql2shp
strk strk at keybit.net
Wed Sep 1 10:52:35 PDT 2010
On Wed, Sep 01, 2010 at 06:29:56PM +0100, Mark Cave-Ayland wrote:
> strk wrote:
> >>Checking the resulting file size is not the right way to be trying to
> >>detect whether the query returned > 0 rows. It strikes me that the best
> >>way to detect this would be to return a different exit code from
> >>pgsql2shp if no rows are returned - would this work for you?
> >I'd go stricter to "if an ERROR occurred" rather than
> >"if no rows are returned".
> >Just in case one day we'll add a flag to specify the geometry type
> >thus allowing creation of empty-but-structuted shapefiles starting
> >from a table "template".
> >--strk;
> This is exactly how the new code in trunk currently works - you get an
> exit code of 0 to indicate success, and an exit code of 1 if an error
> occurred. I was thinking of adding a new exit code of 2 to indicate
> success, but also that 0 records were processed.
I can't see how this was a success in the reporter's case.
Could not determine a geometry type, so what could it have
written in the .shp file ?
It even printed an ERROR message.
How's that a success ?
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
