[postgis-users] ST_Intersection problems
L Bogert-O'Brien
dlawbob at ncf.ca
Thu Sep 2 09:57:58 PDT 2010
Hi again,
My main question here is what is a geometry type of ST_GEOMETRY and
why is it returned from an ST_INTERSECTION of some multipolygons, but
not others that look very similar? How can I manage these
ST_GEOMETRY types so that I can add them to my output table as
multipolygons just like the rest?
A recap of the problem:
I am trying to clip a file with thousands of adjacent multipolygons
(ca_ea_dbf) with one big multipolygon (ca_dcf) which represents the
whole land mass with holes for lakes. I was getting ERROR: new row
for relation "ca_ea_dbf_clp" violates check constraint
"enforce_geotype_the_geom_4269" because of the ST_GEOMETRY types.
A big thanks to Regina for getting me closer to what I need by
suggesting an alternate check for the geometrytype, however, I still
need something returned for every multipolygon in ca_ea_dbf, so I
added a LEFT OUTER JOIN and COALESCE to my query as follows:
INSERT INTO y1991.ca_ea_dbf_clp (eauid, pruid, the_geom_4269)
(SELECT ea.eauid, ea.pruid,
COALESCE(ST_MULTI(ST_INTERSECTION(ea.the_geom_4269,
ca.the_geom_4269)),
ea.the_geom_4269)
FROM y1991.ca_ea_dbf ea LEFT OUTER JOIN y1991.ca_dcf ca
ON ST_INTERSECTS(ea.the_geom_4269, ca.the_geom_4269)
AND ST_GEOMETRYTYPE(ST_INTERSECTION(ea.the_geom_4269, ca.the_geom_4269))
LIKE '%Polygon%'
I now get all the entries in the ca_ea_dbf file returned, but the
ones which were of type ST_GEOMETRY are not clipped of course, since
they don't match LIKE '%Polygon%'. Can anyone tell me what this
geometry type is and how to manage it when I get it in the the
results of the intersection? I have tried ST_DUMP on the
multipolygons before the intersection and then using ST_UNION and
ST_MULTI to gather them back into multipolygons after the
intersections, but I still get the geometry constraint error.
Thanks,
Loretta
At 04:25 PM 8/27/2010, L Bogert-O'Brien wrote:
>After I could not make ST_Difference with water bodies work, (as I
>documented in a previous thread
>http://postgis.refractions.net/pipermail/postgis-users/2010-August/027569.html
>), I thought I would try ST_Intersection with a single multipolygon
>of the whole land area that I wanted to keep. So, what I have is a
>lot of multipolygons in one file that are adjacent to each other,
>but some of them extend out into water bodies (ca_ea_dbf), and
>another file with a single multipolygon with all the land I want to
>keep, i.e. it has a smaller outside footprint as well as holes
>within it for lakes (ca_dcf).
>When I did the following:
> ST_MULTI(ST_INTERSECTION(ea.the_geom_4269, ca.the_geom_4269))
> FROM y1991.ca_ea_dbf ea JOIN y1991.ca_dcf ca
> ON ST_INTERSECTS(ea.the_geom_4269, ca.the_geom_4269);
>I got the following error:
>ERROR: new row for relation "ca_ea_dbf_clp" violates check
>constraint "enforce_geotype_the_geom_4269"
>So, then I ran the following to check the type of geometries:
>SELECT
>distinct(st_geometrytype(ST_MULTI(ST_INTERSECTION(ea.the_geom_4269,
>ca.the_geom_4269))))
> ON ea.pruid = '35'
> AND ST_INTERSECTS(ea.the_geom_4269, ca.the_geom_4269);
>and found that there were both st_multipolygon and st_geometry
>types. The geometry field, the_geom_4269, was entered as being a multipolygon.
>So, then I used the following, thinking that maybe there were only a
>few rows that were not multipolygons:
> = ST_GEOMETRYTYPE(ea.the_geom_4269));
>It returned successfully, but there were only 282 of the original
>45996 multipolygons in the ca_ea_dbf returned, even though all the
>missing ones would intersect with the one multipolygon in the
>clipping file. You can see pictures of the files at:
>http://web.ncf.ca/do841/GIS/index.html
>Thanks in advance for any tips you can give me on this
>ST_Intersection problem (or the previous ST_Difference one). I am
>at a loss for what to try next. Could it be that the files are too
>big and complex for postgis to handle-- i.e. too many multipolygons
>in each file? Or am I just doing something wrong? I am fairly new
>with postgis functions, but I have searched the archives to see if
>there have been similar problems before, and other than the ones I
>have tried above, I do not find any that I can manipulate to my
>particular needs.
>Regards,
>Loretta
