[postgis-users] ST_Intersection problems
Paragon Corporation
lr at pcorp.us
Thu Sep 2 14:07:16 PDT 2010
ST_Geometry is returned if an intersection is empty or a geometry
collection.
Leo
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of L
Bogert-O'Brien
Sent: Thursday, September 02, 2010 12:58 PM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] ST_Intersection problems
Hi again,
My main question here is what is a geometry type of ST_GEOMETRY and why is
it returned from an ST_INTERSECTION of some multipolygons, but not others
that look very similar? How can I manage these ST_GEOMETRY types so that I
can add them to my output table as multipolygons just like the rest?
A recap of the problem:
I am trying to clip a file with thousands of adjacent multipolygons
(ca_ea_dbf) with one big multipolygon (ca_dcf) which represents the whole
land mass with holes for lakes. I was getting ERROR: new row for relation
"ca_ea_dbf_clp" violates check constraint "enforce_geotype_the_geom_4269"
because of the ST_GEOMETRY types.
A big thanks to Regina for getting me closer to what I need by suggesting an
alternate check for the geometrytype, however, I still need something
returned for every multipolygon in ca_ea_dbf, so I added a LEFT OUTER JOIN
and COALESCE to my query as follows:
INSERT INTO y1991.ca_ea_dbf_clp (eauid, pruid, the_geom_4269) (SELECT
ea.eauid, ea.pruid,
COALESCE(ST_MULTI(ST_INTERSECTION(ea.the_geom_4269,
ca.the_geom_4269)),
ea.the_geom_4269)
FROM y1991.ca_ea_dbf ea LEFT OUTER JOIN y1991.ca_dcf ca
ON ST_INTERSECTS(ea.the_geom_4269, ca.the_geom_4269)
AND ST_GEOMETRYTYPE(ST_INTERSECTION(ea.the_geom_4269, ca.the_geom_4269))
LIKE '%Polygon%'
I now get all the entries in the ca_ea_dbf file returned, but the ones which
were of type ST_GEOMETRY are not clipped of course, since they don't match
LIKE '%Polygon%'. Can anyone tell me what this geometry type is and how to
manage it when I get it in the the results of the intersection? I have
tried ST_DUMP on the multipolygons before the intersection and then using
ST_UNION and ST_MULTI to gather them back into multipolygons after the
intersections, but I still get the geometry constraint error.
Thanks,
Loretta
At 04:25 PM 8/27/2010, L Bogert-O'Brien wrote:
>After I could not make ST_Difference with water bodies work, (as I
>documented in a previous thread
>http://postgis.refractions.net/pipermail/postgis-users/2010-August/0275
>69.html ), I thought I would try ST_Intersection with a single
>multipolygon of the whole land area that I wanted to keep. So, what I
>have is a lot of multipolygons in one file that are adjacent to each
>other, but some of them extend out into water bodies (ca_ea_dbf), and
>another file with a single multipolygon with all the land I want to
>keep, i.e. it has a smaller outside footprint as well as holes within
>it for lakes (ca_dcf).
>When I did the following:
>ea.eauid, ea.pruid,
> ST_MULTI(ST_INTERSECTION(ea.the_geom_4269, ca.the_geom_4269))
> FROM y1991.ca_ea_dbf ea JOIN y1991.ca_dcf ca
> ON ST_INTERSECTS(ea.the_geom_4269, ca.the_geom_4269);
>I got the following error:
>ERROR: new row for relation "ca_ea_dbf_clp" violates check constraint
>So, then I ran the following to check the type of geometries:
>SELECT
>distinct(st_geometrytype(ST_MULTI(ST_INTERSECTION(ea.the_geom_4269,
>ca.the_geom_4269))))
> ON ea.pruid = '35'
> AND ST_INTERSECTS(ea.the_geom_4269, ca.the_geom_4269);
>and found that there were both st_multipolygon and st_geometry types.
>The geometry field, the_geom_4269, was entered as being a multipolygon.
>So, then I used the following, thinking that maybe there were only a
>few rows that were not multipolygons:
>ea.eauid, ea.pruid,
> = ST_GEOMETRYTYPE(ea.the_geom_4269));
>It returned successfully, but there were only 282 of the original
>45996 multipolygons in the ca_ea_dbf returned, even though all the
>missing ones would intersect with the one multipolygon in the clipping
>file. You can see pictures of the files at:
>http://web.ncf.ca/do841/GIS/index.html
>Thanks in advance for any tips you can give me on this ST_Intersection
>problem (or the previous ST_Difference one). I am at a loss for what
>to try next. Could it be that the files are too big and complex for
>postgis to handle-- i.e. too many multipolygons in each file? Or am I
>just doing something wrong? I am fairly new with postgis functions,
>but I have searched the archives to see if there have been similar
>problems before, and other than the ones I have tried above, I do not
>find any that I can manipulate to my particular needs.
>Regards,
>Loretta
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
