[postgis-users] Nearest Neighbour on a polygon gemeotry to a given point
David William Bitner
bitner at gyttja.org
Tue Sep 7 05:18:01 PDT 2010
Dave,
You can turn your polygon into a line that is the boundary and then use the
linear referencing functions to return the nearest point along that line to
your input point.
select
st_line_interpolate_point(
st_exteriorring(polygongeometry),
st_line_locate_point(
pointgeometry
David
On Tue, Sep 7, 2010 at 6:55 AM, David Potts <dave.potts at pinan.co.uk> wrote:
> I have a series of x/y values that represent towns and a coastline that
> that is encoded as a Polygon.
> I want to return the nearest point on the polygon to a town. I have seen
> the item
> http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgis_nearest_neighbor_generic
> Which seems to be fine if you both objects that your are searching are
> point data or have a centroid of some type.
> What is the best solution, turn my coastal outline polygon in to a series
> of x/y values and use the solution from postgis_nearest_neighbor_generic,
> or is there some better way?
> regards
> Dave.
> Any views expressed in this message are those of the individual sender,
> except where the sender specifically states them to be the views of the
> Pinan Software
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100907/11afb0a3/attachment.html>
