[postgis-users] Nearest Neighbour on a polygon gemeotry to a given point
David Potts
dave.potts at pinan.co.uk
Tue Sep 7 05:27:21 PDT 2010
hi
Thank you, I will have a play with this.
> Dave,
> You can turn your polygon into a line that is the boundary and then use
> the
> linear referencing functions to return the nearest point along that line
> to
> your input point.
> select
> st_line_interpolate_point(
> st_exteriorring(polygongeometry),
> st_line_locate_point(
> pointgeometry
> David
> On Tue, Sep 7, 2010 at 6:55 AM, David Potts <dave.potts at pinan.co.uk>
> wrote:
>> I have a series of x/y values that represent towns and a coastline that
>> that is encoded as a Polygon.
>> I want to return the nearest point on the polygon to a town. I have
>> seen
>> the item
>> http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgis_nearest_neighbor_generic
>> Which seems to be fine if you both objects that your are searching are
>> point data or have a centroid of some type.
>> What is the best solution, turn my coastal outline polygon in to a
>> series
>> of x/y values and use the solution from
>> postgis_nearest_neighbor_generic,
>> or is there some better way?
>> regards
>> Dave.
>> Any views expressed in this message are those of the individual sender,
>> except where the sender specifically states them to be the views of the
>> Pinan Software
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> David William Bitner
Pinan Software
