[postgis-users] get segment of multiline between two points
Paragon Corporation lr at pcorp.us
Fri Sep 10 10:48:44 PDT 2010
Marco,
Yes.
If you are using PostGIS 1.5 or above you can use ST_DumpPoints to dump the
points out which is a bit faster than ST_PointN (or you can use ST_Point)
http://www.postgis.org/documentation/manual-svn/ST_DumpPoints.html
For lower versions you can use ST_PointN
http://www.postgis.org/documentation/manual-svn/ST_PointN.html
Leo and Regina
http://www.postgis.us
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Marco
Sent: Friday, September 10, 2010 1:15 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] get segment of multiline between two points
as the subject I've two points on a layer multiline and I need all the
points included in that segment to draw on the client side.
is this possible?
thanks
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
