[postgis-users] get segment of multiline between two points
Marco
marcpat at katamail.com
Sat Sep 11 08:27:00 PDT 2010
Thanks, I tried this function, but it returns all points and I need only that
are inside a segment between two points.
ie:
MULTILINESTRING((0 0,1 1,1 2,2 3,3 2,5 4))
POINT(1 1) POINT(3 2)
I want LINESTRING(1 1,1 2,2 3,3 2)
Il 10/09/10 19.48, Paragon Corporation ha scritto:
> Marco,
> Yes.
> If you are using PostGIS 1.5 or above you can use ST_DumpPoints to dump the
> points out which is a bit faster than ST_PointN (or you can use ST_Point)
> http://www.postgis.org/documentation/manual-svn/ST_DumpPoints.html
> For lower versions you can use ST_PointN
> http://www.postgis.org/documentation/manual-svn/ST_PointN.html
> Leo and Regina
> http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Marco
> Sent: Friday, September 10, 2010 1:15 PM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] get segment of multiline between two points
> Hi,
> as the subject I've two points on a layer multiline and I need all the
> points included in that segment to draw on the client side.
> is this possible?
> thanks
> postgis-users mailing list
