[postgis-users] sum dot product of outward normal vectors of polygon segments to given direction
Henri De Feraudy
feraudyh at yahoo.com
Mon Sep 13 01:56:07 PDT 2010
Hello, I'm trying to calculate how much a polygon "points" in a given
direction.
This is to calculate how much light would come from a given light source.
This means that for each segment of its outer ring I want to calculate the
scalar (dot) product of
outward normal vector (whose magnitude is the segment's length) and the given
vector.
One idea is to rotate the polygon, and the given vector simultaneously so that
the given vector is vertical and
then calculate the width of the bounding box.
Any comments?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100913/018353d2/attachment.html>
