[postgis-users] help on converting points to polygon.
Nicholas I
nicholas.domnic.i at gmail.com
Mon Sep 13 03:56:38 PDT 2010
I want to create a polygon from the given points and clip the area's within
the polygon.
I just tried with the below one to create a polygon,
\d test_polygon;
Table "public.test_polygon"
Column | Type |
Modifiers
gid | integer | not null default
nextval('test_polygon_gid_seq'::regclass)
name | character varying(254) |
the_geom | geometry |
Indexes:
"test_polygon_pkey" PRIMARY KEY, btree (gid)
Check constraints:
"enforce_dims_the_geom" CHECK (st_ndims(the_geom) = 2)
"enforce_geotype_the_geom" CHECK (geometrytype(the_geom) =
'MULTIPOLYGON'::text OR the_geom IS NULL)
"enforce_srid_the_geom" CHECK (st_srid(the_geom) = 4326)
*INSERT INTO test_polygon VALUES (3,'test',PolyFromText('POLYGON((78.76708
14.04584,81.54662 14.04584,78.78906 11.25531,81.53564 11.25531,78.76708
14.04584))'));
i get a message saying,
14.04584))'));
*ERROR: new row for relation "test_polygon" violates check constraint
"enforce_geotype_the_geom"*
*Can anyone help me how do i form a polygon with these points.*
Thank you
-Nicholas I
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100913/7755394a/attachment.html>
