[postgis-users] help on converting points to polygon.
Nathan Gerber
ngerber999 at gmail.com
Mon Sep 13 05:18:33 PDT 2010
Your table is setup to accept only MULTIPOLYGONs. Either adjust your table
constraint to allow regular polygons or convert your polygon to a
MULTIPOLYGON.
Nathan Gerber
On Mon, Sep 13, 2010 at 6:56 AM, Nicholas I <nicholas.domnic.i at gmail.com>wrote:
> Hi,
> I want to create a polygon from the given points and clip the area's
> within the polygon.
> I just tried with the below one to create a polygon,
> \d test_polygon;
> Table "public.test_polygon"
> Column | Type |
> Modifiers
> gid | integer | not null default
> nextval('test_polygon_gid_seq'::regclass)
> name | character varying(254) |
> the_geom | geometry |
> Indexes:
> "test_polygon_pkey" PRIMARY KEY, btree (gid)
> Check constraints:
> "enforce_dims_the_geom" CHECK (st_ndims(the_geom) = 2)
> "enforce_geotype_the_geom" CHECK (geometrytype(the_geom) =
> 'MULTIPOLYGON'::text OR the_geom IS NULL)
> "enforce_srid_the_geom" CHECK (st_srid(the_geom) = 4326)
> *INSERT INTO test_polygon VALUES (3,'test',PolyFromText('POLYGON((78.76708
> 14.04584,81.54662 14.04584,78.78906 11.25531,81.53564 11.25531,78.76708
> 14.04584))'));
> i get a message saying,
> 14.04584))'));
> *ERROR: new row for relation "test_polygon" violates check constraint
> "enforce_geotype_the_geom"*
> *Can anyone help me how do i form a polygon with these points.*
> Thank you
> -Nicholas I
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100913/31dd80e8/attachment.html>
