[postgis-users] AsSvg
Bob Pawley rjpawley at shaw.ca
Mon Sep 13 09:46:45 PDT 2010
Rick - thanks for answering.
I am in the process of learning a little XML.
I understood that a query such as 'Select AsSvg(the_geom) from p_id.image' went to Postgis and the return (the geometry) comes back.
I think you are saying that this is also in the xml path and xml interprets this expression differently than 'Select the_geom from p_id.image'
Bob
Sent: Monday, September 13, 2010 9:08 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] AsSvg
Not sure what you are asking, but I'll take a stab in the dark.
When you retrieve geometry as SVG what you get back is the contents of a path attribute node.
So if an SVG path element is written <path d="X"/> the result of the query is "X", or the value of the 'd' (data) attribute, not an XML element, and certainly not a valid SVG document.  You have to construct these yourself.
On Mon, Sep 13, 2010 at 12:00 PM, Bob Pawley <rjpawley at shaw.ca> wrote:
  Hi
  I may be on the wrong list but xml and Delphi guys that know Postgis seem to be few and far between.
  I`m using the following to display the binary data on a memo component as text.
   PSQLQUery1.SQL.Add('Select the_geom from p_id.image');
      PSQLQUery1.SQL.Add ('where p_id.image.p_id_id = ''1534''');
      PSQLQUery1.Open;
  This works fine.
  When I change it to select AsSvg the xml consider assvg as another node and the geometry data does not appear.
   PSQLQUery1.SQL.Add('Select AsSvg(the_geom) from p_id.image');
      PSQLQUery1.Open;
  If any one can suggest a possible reason for this behavior It would be appreciated.
  Bob
  postgis-users mailing list
  postgis-users at postgis.refractions.net
  http://postgis.refractions.net/mailman/listinfo/postgis-users
Cheers!
Rick
Eeny, Meeny, Jelly Beanie, the spirits are about to speak!
        -- Bullwinkle Moose
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100913/0dc5fe2c/attachment.html>
