[postgis-users] AsSvg
Rick
graham.rick at gmail.com
Mon Sep 13 09:08:51 PDT 2010
Not sure what you are asking, but I'll take a stab in the dark.
When you retrieve geometry as SVG what you get back is the contents of a
path attribute node.
So if an SVG path element is written <path d="X"/> the result of the query
is "X", or the value of the 'd' (data) attribute, not an XML element, and
certainly not a valid SVG document. You have to construct these yourself.
On Mon, Sep 13, 2010 at 12:00 PM, Bob Pawley <rjpawley at shaw.ca> wrote:
> Hi
> I may be on the wrong list but xml and Delphi guys that know Postgis seem
> to be few and far between.
> I`m using the following to display the binary data on a memo component as
> text.
> PSQLQUery1.SQL.Add('Select the_geom from p_id.image');
> PSQLQUery1.SQL.Add ('where p_id.image.p_id_id = ''1534''');
> PSQLQUery1.Open;
> This works fine.
> When I change it to select AsSvg the xml consider assvg as another node and
> the geometry data does not appear.
> PSQLQUery1.SQL.Add('Select AsSvg(the_geom) from p_id.image');
> PSQLQUery1.Open;
> If any one can suggest a possible reason for this behavior It would be
> appreciated.
> Bob
> postgis-users mailing list
Cheers!
Rick
Eeny, Meeny, Jelly Beanie, the spirits are about to speak!
-- Bullwinkle Moose
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100913/f276229b/attachment.html>
