[postgis-users] Cannot install postgis 1.5.1 on Postgres 9.0 beta1
psg
psg at cooldog.com
Thu Sep 16 08:08:17 PDT 2010
Has anyone got a solution for this? I'm trying to build on Centos 5.4 with
PostgreSQL 9.0RC1.
My best guess is that it is failing to build the extension binary, but I
don't know why.
Here's where the "make install" breaks:
PostGIS was built successfully. Ready to install.
make -C postgis install
make[1]: Entering directory `/usr/src/postgis-1.5.1/postgis'
Makefile.pgxs:17: warning: overriding commands for target `install'
/usr/pgsql-9.0/lib/pgxs/src/makefiles/pgxs.mk:99: warning: ignoring old
Makefile.pgxs:63: warning: overriding commands for target `installdirs'
/usr/pgsql-9.0/lib/pgxs/src/makefiles/pgxs.mk:147: warning: ignoring old
Makefile.pgxs:82: warning: overriding commands for target `uninstall'
/usr/pgsql-9.0/lib/pgxs/src/makefiles/pgxs.mk:171: warning: ignoring old
/bin/mkdir -p '/usr/pgsql-9.0/lib'
'/usr/pgsql-9.0/share/contrib/postgis-1.5'
make[1]: /usr/pgsql-9.0/share/contrib/postgis-1.5: Command not found
make[1]: *** [installdirs] Error 127
Joel Pearson-2 wrote:
> Hi,
> Postgis 1.5.1 compiles ok on Postgres 9.0 beta1, but when I run make
> install
> it fails:
> `/home/japearson/postgis/postgis-1.5.1/postgis'
> /usr/pgsql-9.0/lib/pgxs/src/makefiles/pgxs.mk:100: warning: ignoring old
> /usr/pgsql-9.0/lib/pgxs/src/makefiles/pgxs.mk:148: warning: ignoring old
> /usr/pgsql-9.0/lib/pgxs/src/makefiles/pgxs.mk:172: warning: ignoring old
> make[1]: Leaving directory `/home/japearson/postgis/postgis-1.5.1/postgis'
> make: *** [postgis-install] Error 2
> Any ideas? Is postgis simply incompatible with Postgres 9.0beta at the
> moment?
> Cheers,
> -Joel
> Joel Pearson
> Software Engineer
> Agile Digital Engineering Pty Ltd
> A.B.N. 98 106 361 273
> A: 5/28 Eyre St Kingston ACT 2604
> P: +61 1300-858-277
> F: +61 1300-858-477
> M: +61 (0) 405-417-843
> E: joel.pearson at agiledigital.com.au
> W: http://www.agiledigital.com.au
> postgis-users mailing list
View this message in context: http://old.nabble.com/Cannot-install-postgis-1.5.1-on-Postgres-9.0-beta1-tp28531067p29729512.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
