[postgis-users] convert sql table to xml by using java script
zhang zhe
luckyclare at hotmail.com
Fri Sep 17 01:51:37 PDT 2010
Hello,
I want to convert postgres sql table to XML document automatically by using javascript code. For instance, if user open the URL,it will pop-up a window that allow user to save the XML file that converted from postgres table to any directory. I found some information from the Postgres home page, but it give only very general information.
http://www.postgresql.org/docs/8.2/static/datatype-xml.html
Does anyone has experience with this kinds of task. Is it possible to convert postgres table automatically to XML file.
Thank you
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100917/89610ae6/attachment.html>
